Performance Brakes?
Old May 30, 2003 | 11:59 AM
87LTcamaro's Avatar
Performance Brakes?
my front rotors are shot! what brand is the best bang for the buck? ive got probably 300hp at the rear wheels. i was wondering if i should just get the stock replacement front rotors and pads or should i get the vented and/or slotted rotors? its gonna be like a $200 difference. does anyone know where the best place to get these is? thanks for all the help!
Old May 31, 2003 | 12:26 PM
87LTcamaro's Avatar
nobody has any performance rotors?
Old May 31, 2003 | 05:23 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Are you just wanting to replace your front rotors or upgrade your braking system? If so, look into Power Slot rotors, I've heard many good things about them. But why not upgrade to a bigger system while you're at it?
Ed
Old Jun 1, 2003 | 01:20 PM
87LTcamaro's Avatar
thx for the reply....youre the only person that has. anyway my front rotors are bad......so i was wanting to know if i should go ahead and upgrade...but i dont know where to start...i would like to know what other ppl are running and what works and what doesnt.
Old Jun 1, 2003 | 01:23 PM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
I called up Summit Racing and ordered some Powerstop cross drilled front rotors and Powerstop pads.
I'm going to install them soon
Old Jun 1, 2003 | 07:32 PM
machinist's Avatar
Read these three threads completely through. You will be much better educated about brake upgrades after reading them, and can make an informed decision on what to do with your brakes.
https://www.thirdgen.org/techbb2/sho...hreadid=142115
https://www.thirdgen.org/techbb2/sho...hreadid=175533
https://www.thirdgen.org/techbb2/sho...hreadid=181706
Old Jun 2, 2003 | 12:30 AM
Kandied91z's Avatar
should have check the for sale section.
i have a set of gm cross drilled/slotted rotors barely used with new calipers and earl's braided line for 250.
gotta love the larger rotors though!
Vintageracer
Jan 10, 2020 05:33 PM
deracer
Apr 11, 2016 12:04 AM
Reddeath210
Oct 6, 2015 08:20 AM
gta90
Sep 15, 2015 04:00 PM
zayne0
Aug 24, 2015 07:22 PM
