Jamex Springs....What size tires?
Old Jun 1, 2003 | 01:08 PM
Adamsy87's Avatar
hey guys,
So im starting to build up my suspension on my 87 bird and have a few questions....I have located a set of Jamex springs and am most likely going to get them. my question is what size tires do i need to run with the lowered car? Will my 245/50/16 rub at all....
Are the LCA relocation brakets necessay when running these springs?
Also, if anyone has experience with these springs ie. good, bad ride?
Lastly if anyone has a picture with these springs on there car that would be awesome, as i am really curious to see what it will look like!
If anyone has reccomendations on STB, subframe connectors, or wonderbar let me know!
Thanks in advance guys!
Old Jun 1, 2003 | 09:18 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Here you are, a before and after with Jamex springs.
http://www.lt1intake.com/before_after.htm
I am running 255/50/16's all around with no problems. This is on factory IROC rims.
Old Jun 1, 2003 | 10:41 PM
Adamsy87's Avatar
Awesome!! Thanks a lot.....
Wow that really makes a difference, those springs look MINT!
I can't wait now! Are you using LCA relocation brackets?
Thanks a lot!
Old Jun 2, 2003 | 03:27 PM
Engine: 4.0L
Thanks a lot!
Yes I do have LCA brackets. They are almost a must for a lowered car that visits the dragstrip from time to time.
Hotrodboba400
Dec 10, 2019 07:07 PM
SG91camaro
Sep 5, 2015 10:27 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
