Rear Shock Removal, help ASAP
Old Jun 7, 2003 | 12:22 AM
rubber_lee's Avatar
Someone Please help. 1 of my rear shocks is rusted really bad. I did the other side with out any problems. I stared using a vise grip then the top portion broke off. Any suggestions will help thanks folks.
Old Jun 7, 2003 | 07:33 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Where exactly did it break?
Old Jun 7, 2003 | 11:00 AM
rubber_lee's Avatar
I was able to turn the bolt like 2 full turns. the notch right above the bolt broke off. Ill mayby try an air hammer but am not sure what will work best.
Old Jun 7, 2003 | 11:15 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Put your Vise-Grips on the exposed shaft of the shock underneath the car, and use a ratchet and socket on the nut.
Old Jun 7, 2003 | 02:42 PM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
i removed mine about 3 days ago and had to do the same. hehehehehe, i just took a pair of vise grips and held on real tight while a friend loosed the bolts.
Old Jun 8, 2003 | 03:36 AM
rubber_lee's Avatar
Thanks guys. That worked for the right side but had to cut the bolt on the other side. That friggin bolt took almost an hour to hack off. I got my lakewood c arms, dropzone springs and kyb shock in. took me 2 days and will need 1 more for my adj. panhard bar and poly torque arm bushing. Thanks again.
Old Jun 8, 2003 | 12:07 PM
Engine: peanut LB9
you thinkthats ong my cars been off the road for 2 weeks now. i have the whole thing apart/ i'm waiting for the hotchkis springs,kyb struts and shocks, spohn lca's, spohn panhard rod, new busings ever where, my new 36/24 mm power coated sway bars, and some more stuff can't remeber it all- oh and i cant find a 4th gen rear
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
LT1Formula
Nov 16, 2015 01:13 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
3rdgenparts
Aug 8, 2015 07:09 PM
