IS 1.6" TOO LOW????? help asap!
Old Jun 25, 2003 | 09:07 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
i need to know if 1.6" drop would be too low. i have a 1991 z with 245/45/17 tires and i was planning on installing an adjustable panhard bar but not new spindles, shocks, or lca relocation brackets. i might get the brackets in the future but not right now. would i have rubbing issues or ground clearance issues with a 1.6" drop????????? i need some advice asap!
thanks in advance
Ben
Old Jun 25, 2003 | 11:28 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
you'll be fine, make sure to get an alignment when you are done.
also i would get relocation brackets as soon as you can, they willl really help the wheel hop you will encounter after lowering.
db057
Jan 10, 2020 08:55 PM
BrianI
Oct 3, 2015 12:57 PM
Damon
Sep 26, 2015 04:29 PM
92projectcamaro
Sep 24, 2015 08:09 AM
327IROC85
Sep 23, 2015 12:11 AM
