ES swaybar/misc part numbers.
Old Jul 8, 2003 | 09:11 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Alright, I have gotten my F41 sway bars in finally. Already have ES endlinks.
Needing the bar to frame bushings for them, I turned to summit/ES.
Found front one
ENS-3-5131, 34mm Greasable, No Problem
21mm rear bar, having problems. Whats the difference between ens-9-5157r, and ens-9-5158r???
While im at it, I have already done the ES trans mount, but wondered about the lower "biskit" ones, found part # on ES site being 3-1109, but I cant find this is summits listing???
Also while Im at it, tourqe arm. How do I know if I have the flange in, or flange out style, I'm kinda lost on that one. Its a 91 RS v6.
Thanks for the help!!!
Old Jul 10, 2003 | 09:41 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: ES swaybar/misc part numbers.
On the torque arm, it was made in two different styles. The cross section of the arm looks like a W or C in shape. The difference between the two styles is whether the lips (or opening) of the cross section faces toward or away from the driveshaft.
Summit may stock, and can always get any ES part.
RBob.
Old Jul 10, 2003 | 12:03 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The http://www.energysuspension.com website tells you how to identify which torque arm bushing you need; either the lips face the driveshaft, or face away from it- they have pictures up. Ah, what the hell, why not.... here's the link: http://www.energysuspension.com/cam2.html
3-1109 is on their website; you just forgot the bushing's color code! So ENS-3-1109G (Graphite impregnated black) or ENS-3-1109R (red) or whatever, but the site says they're backordered... Summit's website doesn't have a provision for "Special Order", so you need to give 'em a call.
See this old message of mine for part numbers for the bushings... https://www.thirdgen.org/techbb2/sho...threadid=58782 That front bushing you have is correct but it's not greaseable. You're just getting the center bushing, no outer bracket- our brackets use offset bolts. If you search this forum for "greasable", you'll find out how some people made their bushings greaseable.
Old Nov 11, 2010 | 04:57 PM
CarlosGZ28's Avatar
Dear guys, I buyed the whole E/S Master Bushings Kit (3.18131R), and on the Transmission Mounts came that Little Biskit with part number 3.1109 or Secondary Crossmember Mounts.
So.. Where in the heck is the X member? Where in the heck goes this kit, i really don´t understand the Installation Instructions...
Maybe a pic?
Carlos
Old Nov 11, 2010 | 05:09 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
the secondary crossmember is not installed on most cars, usually the v6 cars have them. Its just a different type of crossmember for the trans, there is another, more rare and PITA fluid filled mount too. The secondary setup has a crossmember, then another smaller crossmember bolted on top of it with those small flat round bushings in between, then the trans mount on that.
you probably dont need those particular parts, just toss them.
Old Nov 11, 2010 | 05:27 PM
CarlosGZ28's Avatar
Thanks a lot... Recently discover it... is best know that I don´t need it than toss them...
Best Regards!
Old Nov 11, 2010 | 06:04 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
just make sure you dont need them before you toss them
Old Nov 11, 2010 | 08:44 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
For the sake of general info, here's a pic of the secondary cross member along with info about what cars had or may have been equipped with it:
https://www.thirdgen.org/forums/hist...ss-member.html
JamesC
LT1Formula
20
Nov 14, 2015 12:02 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
