Can't 60ft for ****.
Old Jul 12, 2003 | 11:00 PM
IROC4LIFE's Avatar
Car: 1986 IROC-Z
Engine: SBC
Transmission: Manual Th-350
Axle/Gears: 9" Moser 3.89's Spool.
2.45 60ft's Need Help.
Hey Everyone.
Well Ive been takin my IROC out to the races lately and ive found since Ive made some changes I can't 60ft for ****.
Here are the cars specs.
1986 IROC-Z
350ci (300hp) Th-350/2500Stall/10bolt Posi with 3:23 Gears.
Spohn Th-350 Swap TQ arm -1' pinion angle, Lakewood LCA's, Stock Panhard, CE 50/50 Drag Shocks, Stock Springs all around, Stock replacement Struts.
16inch IROC-Z rims with Goodyear Eagle GT2's 245/50/16 all around. (30-40PSI)
I can usally stall the converter to 2200-2300RPM when I launch and spin like crazy to a 2.45-2.50 60ft. with a 14.4@102MPH Uncorrected @3600ft.
Ive Tried differnt launch RPM's differnt Tire PSI and even ET's Streets. (which caused a HUGE bog)
Comments Suggestion's please.
Old Jul 13, 2003 | 12:23 AM
MdFormula350's Avatar
lol, i did a crap load of suspension also, and still cant hook up at my local track, but it seems to hook better on the streets. maybe at the track i give it to much gas.
maybe alittle more negative pinion angle, might want to try that.
Old Jul 13, 2003 | 12:40 AM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Whatever you do, don't go to the track with anywhere near 40 psi expecting to hook.
Old Jul 13, 2003 | 07:34 AM
ede's Avatar
ede
unhook the front sway bar, or the left side. air bags in the rear coils, slicks, SFCs
Old Jul 13, 2003 | 01:10 PM
IROC4LIFE's Avatar
Car: 1986 IROC-Z
Engine: SBC
Well I have SFC's, Tried Slicks (ET Streets) and I really dont wanna unhook the swaybar.
So I guess its pretty much the tires then? Thats is what I was thinking, cause you would think with the Spohn Arm and Drag Shocks with LCA's and SFC's it would hookup.
Old Jul 13, 2003 | 01:33 PM
AFatHippo's Avatar
Car: '88 Camaro
Engine: 355
the torque arm, LCAs, and SFCs are probably allowing more power to get to the pavement making it a little more difficult.
here is what i would try, but cant guarantee it would work. first, set the torque arm for more negative pinion angle. always run the tires at 32-35 psi. try stalling it up to 1000-1500 and experiment in that rpm range. if you havent improved after all that, i guess its time to spend a little $$$. buy lca relocation brackets and an air bag in the rear passenger spring. you could try 255/50 or 265/50 rear tires. youd have to do a little research for what brands and models and stuff of tires, but i bet theres a better street tire out there.
Old Jul 13, 2003 | 08:45 PM
IROC4LIFE's Avatar
Car: 1986 IROC-Z
Engine: SBC
I agree I think its all in the tires now.
darwinprice
17
Oct 11, 2015 11:51 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TRAXION
Aftermarket Product Review
87
Nov 22, 2008 10:33 PM
90Iroc-Zee
Jul 10, 2001 02:54 AM
