moly vs. mild steel
Old Jul 17, 2003 | 09:08 AM
colonboy14's Avatar
Car: Trans Am
moly vs. mild steel
OK, I've read all the posts and I understand how moly can be stronger if properly heat treated, and how if it isn't it can be frail. But Steve Spohn said in another thread that he wouldn't get a moly k-member on a street car.
When is it OK to use moly, and when should you use mild steel? If moly is stronger when made properly, what's the problem?
Old Jul 17, 2003 | 09:21 AM
ede's Avatar
ede
moly doesn't flex as much as MS, instead it cracks. i had a CM chassis once and it was prone to cracking and actually not as good because it never flexed and transfered weight like i would of liked. CM is also harder to weld, or requires more time and effort to make an acceptable weld. unless i was concerned about saving every ounce i could or needing every little bit of strength i could find i'd never run CM anything.
Old Jul 17, 2003 | 10:19 AM
colonboy14's Avatar
Car: Trans Am
Ahhhhhh, OK. Thanks
Fanatic1074
Oct 3, 2022 05:57 AM
3rdgenparts
May 21, 2016 11:50 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
LT1Formula
Oct 8, 2015 08:34 PM
FueledSoul
Sep 30, 2015 09:18 PM
