Which would go first?
Old Aug 12, 2003 | 02:07 AM
Frains90RS's Avatar
Car: 1990 Camaro RS
Engine: LO3: 305 TBI
Axle/Gears: 1997 Trans Am rear w/ posi -3.23
I have a lot of plans for my suspension/chassis/brakes, but theres so much I want to do and not enough cash to save time and do it all at once. What would be the best way to start off?and which would be best to do together?
Plans :
1. Rear end swap from open 10 bolt w/ 2.73 gears and drums-> posi 10 bolt w/ 3.23 gears and 1LE discs
2. Eibach Prokit and KYB GR2 fronts/ Gas-A-Justs rears
3. 1LE front disc upgrade
4. Front end polygraphite rebuild kit from PST
5. Adjustable torque arm (no brand decision)
6. TDS SFC's and wonderbar (and swaybars)
...all the rear supension tidings and maybe even a T56 swap down the line. Any advice helps out, Thanks.:lala:
Old Aug 12, 2003 | 08:38 AM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
1. TDS SFC's and wonderbar (and swaybars)
2. Front end polygraphite rebuild kit from PST
3. Eibach Prokit and KYB GR2 fronts/ Gas-A-Justs rears
4. 1LE front disc upgrade (or C5 Brake upgrade)
5. Rear end swap from open 10 bolt w/ 2.73 gears and drums-> posi 10 bolt w/ 3.23 gears and 1LE discs
6. Adjustable torque arm (no brand decision)
Thats the order I would go.
Old Aug 12, 2003 | 09:06 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
other than SFC's, before modding , fix what is worn out. so replace bushings ect.
Old Aug 12, 2003 | 09:32 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
the SFCs and other braces first to stop most of the squeeks and such..
at that point, replace everything thats worn...
then, now that you have a solid base, you can move onto the aftermarket parts....
Old Aug 12, 2003 | 12:16 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Do the springs when you change the control arm bushings. Those are two jobs you'll never want to do separately.
Old Aug 12, 2003 | 01:22 PM
Frains90RS's Avatar
Car: 1990 Camaro RS
thanks guys
Appreciate the help, you guys are always helpful. Thanks. Any suggestions for the torque arm or other rear end suspension components?
Old Aug 13, 2003 | 02:58 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I would do the torque arm later when you will have the power to take advantage of it. SFC's first are a must. I would replace anything else that was worn out like the people said before. I would then lower the car, However with an adjustable panhard rod and LCA relocation brackets. LCA's are a nice cheap mod as well. After that alone your car will handle and stop better. Brake upgrades are expensive but soooooo worth it. You have to save up a lot and kinda do it one big shabang unlike the rest of the suspension where you can buy it piece by piece.
