75 10 bolt posi into 82 Z
Old Aug 22, 2003 | 10:04 PM
Battery's Avatar
Car: 75 & 82 Z-28
Transmission: Saginaw 4 speed
Now I know these do not bolt up, but I cannot find a local rear end around here under 400$. And by the time I get one shipped, it is over 400$ anyways. I have the 10 bolt posi, can I make it work, thanks guys.
Old Aug 22, 2003 | 10:30 PM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
if you have a rear end shop that knows what they're doing, you can get the spring perches and LCA brackets and shock mounts welded on and then some kind of torque arm mount would have to be fabricated. It might also need to be shortened, chances are, the mods to make it work are still gonna be over $400...i assume thats your budget...
Old Aug 23, 2003 | 06:41 AM
ede's Avatar
ede
sure it'd work. all you need to do is relocate the brackets to the new rear and make provisions for a torque arm, should be that hard to do. might want to check the width too, might have to change that but i bet it'd work.
F-body driver
Mar 6, 2023 11:44 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
djmarch
Sep 13, 2015 01:35 PM
Third_Gens_Rule
Sep 3, 2015 06:56 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
