89 rear disc posi
Car: 1998 Camaro Z28
Engine: 6.0L
89 rear disc posi
a friend of mine has a rear end out of an 89 350tpi for $200, its rear disc w/ 2.77 posi gears. before i buy it i want to know what size the ring gear is so i can upgrade to 3.42 or 3.73. any idea what size the ring gear is? he said he doesnt think its a 7.5 inch.
Car: 1986 Firebird
Engine: 2.8 V6
You could probably find a ton of info in the Transmission/Drivetrain forum, but, is the axle a 9-bolt? If so, there's not too many gear ratios available for it, although it's stronger then the 10-bolt axle. All 10-bolt 82-92 f-body axles will have 7.5 or 7 5/8 inch ring gears, and will take either size (7.5 or 7 5/8).
So you might want to skip on it if it's a 9-bolt... unless he takes $150 off the price
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
If it's a 9 bolt then it has a 7.75" ring gear. Another thing that may influence your decision is the fact that the posi in the BW has 4 pinions compared to the 2 in a 10 bolt making the 9 stronger. Check out www.9bolt.com , a pretty good source of parts and info on the Borg Warner rear. I'm putting the final touches on a 9 bolt for my 90 Formula. I've swapped the Saginaw brakes (junk) for the PBRs and bigger rotors. I personally wanted the 2.77 ratio for taking the car out on long trips since I've been using a 3.73 in the OE 10 bolt and am sick of it.
Engine: 6.0L
thanks guys, and im really not sure the reason why i posted in here. guess i wasnt paying attention, lol.
It's from a 350TPI and it's 2.77 gear so it has to be a 9 bolt. The only other ratios available are 3.27-3.45-3.70 and the only place I know of to get the gears are on here: www.9bolt.com (as posted above by Mongoose)
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Randy's Ring and Pinion carry a gear for the 9 bolt. Notice I say a gear... hehe 3.73 going price of 190 bucks, Then another 117 or so for the overhaul kit... new seals and bearings.
It will be noisey from what I heard.
hectre13
Dec 11, 2023 08:14 AM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
