wheel hop
Old Sep 25, 2003 | 07:46 AM
berniezz's Avatar
wheel hop
hi guys
i have a 92 rs w/ 305 auto tran. 190k miles and i'v redone the suspension about a year ago.
new eibach springs, spohn pan hard, sphon sway bars, KYB shocks up front but some cheap brand from auto zone in the rear ( i dont know what i was thinking $19 each).
i just started getting "wheel hop" or bounce/clunking from the passenger side rear wheel when i start from a dead stop.
it only happens when i sort of gun it.
any ideas ?
thanks
Old Sep 25, 2003 | 08:09 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
are you getting a clunk, or is the wheel actualy hopping?
Old Sep 25, 2003 | 08:14 AM
berniezz's Avatar
i think its more of a clunk, as is something is loose however it does feel like the wheel hops due to a little shake from back there.
Old Sep 25, 2003 | 08:15 AM
Dewey316's Avatar
Car: 1990 Camaro RS
i would double check and make sure everything is tight back there first. and check the conditions of the bushings.
also, does it clunk when going over speed bumps or anything of that sort? or just when you hit the loud pedal.
Old Sep 25, 2003 | 08:33 AM
berniezz's Avatar
as far as spped bumps and rr crossings ( they suck here in greensboro, i just got up here from south fla) it makes some noise if i dont creep over them.
Old Sep 25, 2003 | 08:37 AM
Dewey316's Avatar
Car: 1990 Camaro RS
does it make the same noise as you are describing above, when you go over a speed bump?
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
drptop70ss
Oct 4, 2015 09:44 PM
Saxondale
Sep 15, 2015 06:42 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
