For everyone with suspension tech sway bars look inside...
Old Sep 29, 2003 | 04:44 AM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
From what I hear from before everyone says that the suspension tech. sway bars make their car oversteer. Is this true? I recently put suspension tech sway bars and my car handles like a ***! Most people would probably want my cars handling ability. I mean seriously this car can grip almost any turn like crazy. BUT I bought these sway bars atcually because people said it caused extreme oversteer. O_o
Old Sep 29, 2003 | 05:50 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
interesting....
what springs do you have on there? you might try putting your old front bar, with the new rear bar. (assuming the new ones are both larger than what you had).
Old Sep 29, 2003 | 02:01 PM
REVLIMIT's Avatar
Engine: Built L98
as for springs I have the ground control weight jack system set up. Which is...800/175
Yea Im going to try and put a stock front sway bar to see if it helps. I got a stock RS one and also a stock Z28 one guess I'll try both to see which one is better.
Old Sep 29, 2003 | 02:04 PM
Dewey316's Avatar
Car: 1990 Camaro RS
800# springs, and an aftermarket sway bar, you might as well have a solid front axle
Old Sep 29, 2003 | 04:34 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Could the end-link nuts have loosened up somehow? I had that happen after I had just rebuilt my suspension... cornering suddenly went to hell after a day or two. I slid under, and my rear end-links had loosened up. Tightened them back down, and they've been fine. I guess I used too much WD40?
Old Sep 29, 2003 | 05:50 PM
REVLIMIT's Avatar
Engine: Built L98
nah they werent loose...yesterday was a big event and all day I was constantly trying to adjust suspension peices to try and make the car have more over steer. Or atleast get rid of the huge *** understeer problem when sliding. Anyways I changed the front sway bar over to the stock sway bar but left the st rear sway bar and now the car drifts good. The suspension feels alot smoother now also...I guess cause there some play in the front. On top of that I also improved my turning radius...seems that ST front sway bars and 9" wide rims dont work to good. My tires rubbed the bar. O_o
J-money
Jan 4, 2019 09:45 AM
camaro1185
Oct 26, 2015 06:51 AM
J0386
Oct 12, 2015 07:46 AM
87camaro87
Sep 9, 2015 10:29 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
