welding the seams in our cars..
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
anyone here ever done it?
i would assume it would help stiffen the car somewhat.... and with how flexy our cars are to start with, i dont think it would hurt any....
other then making sure the carpets out of the way
any comments, ideas, suggestions?
i would think this would be a easy way to help our cars stiffen up a bit....
any comments, ideas, suggestions?i would think this would be a easy way to help our cars stiffen up a bit....
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I've seen it done but haven't done it myself. There's a LOT of seams on the bottom of the car and I think if you were gonna paint the whole car, I'd do it.
Ed
Ed
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
My cage builder welded in some of my seams...In the rear area especially...He pulled out that sticky liquid nails or whatever they used and mig welded the seams....He even built some steel supports on the pass side where that HUMP is..because it was thin steel and the cage puts stress there....Since it was ALL done at the same time I cant say what effect it really has...I mean the car was waaayy stiffer and felt tight as hell BUT probably has more to do with the cage than welding the seams...The guy welded them for me because he was afraid the cage wuld not be as effective with plates welded to PINCH weld/liquid nails panels.....
Take it for what its worth...
The guy that built it Welds all chassis for ARCA ??sp Trucks..
So he knows his ****..
Car: 87 Firebird Formula
Engine: 305 LG4
This is getting to be a popular mod for the uni-body Cherokees that are taken off-road. Have heard good things about it in that context.
Makes sense to do it where a cage is being installed too.
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
Hey Mr Dude, if you check Third Gen Resource (link on top of the page) and look at the underside pics of the white vert they talk about what they did they mention welding the seems.
no green
Jan 9, 2016 09:22 PM
