What rear suspension should i go with
Car: 1989 IROC-Z
Engine: 350 TPI w. Bolt_ons
Axle/Gears: Dana 44 3.73
Ok im having a problem... when ever i hit a bump however minute there is a loud (outside the car) knocking noise.. This would be my shocks i am assuming im not a suspension expert but thats what i think.
Also i need advise as to how to get my power to the ground instead of in the form of my tires spinning all the way through 1st gear since i just tranfered my a4 to m6..
What shocks should i go with and what else will get my power to the ground. this by the way on my street car but will be visting the track often...
thanks
james
thanks
james
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
check out some QA1 products i have some friends running them in stangs and 4thgens and love them , not cheap though
as far as ur suspeion goes i say get a
Ebaich drag launch springs
QA1 rear shocks
spohn adj. lca's w/ relocation brackets
spohn adj. panhard rod
if that doesn't do it and that should--
isay get some slicks and a beefer rear to match.
this is for a dragf launch setup-
QA1 rear shocks
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
I'm running Spohn's LCA relocation kit, T5 trailing arm kit, and adjustable panrod bar. I'm very happy with them. I have also had great results with Global West products in other projects.
bjpotter
Jan 22, 2019 12:27 PM
