Prop Valve Question, drum to disc
Old Oct 5, 2003 | 02:09 PM
LT1guy's Avatar
Car: 1987 Trans Am
I have a 3.73 disc rear from an 84 TA, which I am swapping into an 87 Firebird. I know the early brakes aren't as good, but the calipers are being rebuilt with the "recall kit" so they should be fine for now.
The 87 has the J50 master cylinder and stock drum brake valve. I have the 84 disc valve (which is standard thread and won't work with the existing MC right?) and a stock 91 master cylinder and drum brake prop valve. I plan to use the stock 87 master cylinder (its in great shape, and its polished!), but wanted to know what prop valve I should use. Can the 91 drum valve be modified, or should I buy a new prop valve? I saw the 1LE valve suggested on another thread, part # 14089496, but wonder if this will work ok considering the car has stock iron calipers in the front and the early iron calipers in the rear.
Any ideas? TomP?
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
redmaroz
Aug 16, 2015 11:40 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
