Which Sub-frame connectors
Old Nov 4, 2003 | 09:28 AM
z28cmr1988's Avatar
I need subframe connectors, and i've narrowed it down to either:
The CompetitionEngineering sfc's
http://www.jegs.com/cgi-bin/ncommerc...65&prmenbr=361
Or the jegster frame ties:
http://www.jegs.com/cgi-bin/ncommerc...05&prmenbr=361
Now, assuming that there is no problem doing any exhaust modifications, which ones are the best or strongest?
For the time being, I plan to use bolt in sfc's and just weld them into place later because I have heard of the bolt hole elongation problems.
Thanks for any feedback. :lala:
Old Nov 4, 2003 | 09:40 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
from the link you posted.
247-3111
82-92, 57-5/8'' Length
NOTE: Will not clear factory installed exhaust system
so the comp. eng. ones won't work without custom exaust work.
i have no experiance with the jegster ones. i know a few people here run them. most people here (i am one of them) is going to suggest something better than the typical bolt in ones, click on the banner at the top that says 'SPOHN'
Old Nov 4, 2003 | 12:51 PM
Adam Jones's Avatar
Do yourself a favor: Spend the extra cash and buy Spohn's.
-AJ
Old Nov 4, 2003 | 02:03 PM
drop-top IROC's Avatar
Engine: 305 TPI (LB9)
Transmission: WC T-5
better yet, buy subframe connectors that truly connect the front and rear subframes: Alston.
(also available by clicking the banner at the top that says "TDS")
Old Nov 4, 2003 | 02:37 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Alston or Spohn...period.
ed
Old Nov 4, 2003 | 04:53 PM
rp_guy's Avatar
Car: '86 Z28
Engine: 305 LG4
Transmission: 700-R4
what are the differences between the spohns and alstons? i know they connect to different areas, but what is each one good for?
Old Nov 4, 2003 | 05:51 PM
Rippin92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: GM T56
Spohns are more for corner carving and Alstons are more for straight line.
z28cmr1988: I've read good things about bolting the Jegsters in then welding them later. And I've heard Comp Engineering ones plain suck.
-Rippin
Old Nov 4, 2003 | 08:40 PM
PhilM's Avatar
Car: Accepting applications...
Yeah, you better believe those CE pieces don't fit stock exhaust. they are made for drag cars with competition exhaust. I put them on my car and had to extensively modify the passenger side connector to clear the pipe. ok, I hacked it to death with the sawzall.
Alston's look really well designed and built, and Spohn knows his stuff, in my opinion.
Old Nov 9, 2003 | 08:22 PM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
OK confusion has set in here. Is Alston's the same as TDS? If it is the same then my vote is for TDS!!!
Old Nov 10, 2003 | 12:51 AM
rp_guy's Avatar
Car: '86 Z28
Engine: 305 LG4
tds sells alstons
Old Nov 10, 2003 | 01:15 AM
joshwilson3's Avatar
Old Nov 10, 2003 | 02:21 AM
rp_guy's Avatar
Car: '86 Z28
Engine: 305 LG4
the only problem i've heard of with alstons is that the block the stock exhaust
if i'm going to just have a daily driver would the spohn's be best?
Old Nov 10, 2003 | 06:38 AM
Dewey316's Avatar
Car: 1990 Camaro RS
i've never heard of any issues with alstons and the factory exaust.
i personly like the spohn design.
91 SrS
Oct 7, 2015 04:32 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
