Anyone have experience with baer brakes and ronal R15s?
Old Nov 29, 2003 | 02:38 AM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
I was wondering if anyone knows what the biggest baer kit you can fit behind the ronal R15s is... I talked to someone with a 13 inch kit. He said he had to grind the calipers down a little to get it to clear. Problem is, there's 4 different 13 inch kits and I don' t know which one it would be.
Old Nov 29, 2003 | 03:28 AM
Kandied91z's Avatar
4 different 13" kits? which ones?
i have a 2 piece track kit and 17's were so close i went 18.
Old Nov 29, 2003 | 01:21 PM
Hg's Avatar
Hg
Car: '87 Z
(Track) PBR 2 Piston, 13" x 1.10" Rotors
(Pro) Alcon 4 Piston, 13" x 1.10" Rotors
(Pro+) Alcon 4 Piston, 13.50" x 1.25" Rotors
(Extreme+) Alcon 6 Piston, 13.50" x 1.25" Rotors
I'm pretty sure it won't be the extreme kit though lol.
Old Nov 29, 2003 | 04:12 PM
Kandied91z's Avatar
well if you have enough money in the funds to go over the track kit i suggest you run a nicer wheel. this way you can tailor design the barrel to fit the caliper if you really want to fit 17's.
i have seen the pro and the track fit behind many stock 4tghen spec 17's however the pro+ and above is pretty close. never seen them behind a ronal 17 though except for your average firehawk wheel which is the same.
dbrochard
Sep 19, 2015 08:13 PM
lock1983
Brakes
Sep 9, 2015 09:08 PM
84 TA NV
Sep 6, 2015 08:02 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
