quick tire question
Old Nov 30, 2003 | 11:17 PM
blackgold84's Avatar
Car: 1984 Z/28 Camaro
Engine: 350ci
Axle/Gears: 9" 3.73 spool
quick tire question
i have tires on my car like most of us here do and these particular tires require air pressure in them, was simply wanting the best way to get the normal psi i should keep them at, im not really sure, i know not to put them to the max psi listed on the tire cause they cant go oevr that, but yeah, it it helps any i have 225/60/15R tires i keep them at about 40 psi on the front, is this sound right or am i just worring to much, i never understood the rear tire front tire difference in pressure, cause my fronts have the motor pushing down, making them have a higher presure, but the rears have no weight... just looking for some answers, thanks
-doug
Old Nov 30, 2003 | 11:59 PM
SuperTrans Man's Avatar
Car: Camaro
Engine: 5.slow
Transmission: 5 speed manual
32 psi all the way around and if u ever notice the tires wearing in the center faster then the two outsides ur over inflated if ur wearing on the two ouside sholders ur under inflated and if ur wearing on the right or left sholders of the tires its going to be alignment just thought i would give ya the some usefull info on tires
Old Dec 1, 2003 | 11:31 AM
Engine: 350ci
thanks alot man
good new is im not completely retardted, yay! My tires only have wear from turning really hard on them, no unusual wear on the rear , and the front, dont show center or edge wear, other than the outside edge from aaggressive driving
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
