master cylinder and prop valve
Car: 86 iroc
Engine: 355 400hp
Transmission: 700r4 race built
Axle/Gears: 4.10 posi
after doing a search i think i have it now.just to make sure, ihave an86 iroc drum brakes and just put in an 86 trans am rear with disc brakes. do i need to change the master cylinder and the prop valve?
Car: 1982 camaro
Engine: built 355 chevy
Transmission: th 350 w/ 3.73 gears
yeah just the proportioning valve, what kind of fittings do you have on yours, i have two proportioning valves for disc brakes that are balloon fittings if your interested, if you have standard double flare i would suggest getting a adjustable one, i went through joe vanCamp and he couldnt get me one with the standard double flare fittings, so i went with the adjustable one, alot less hassle,
Russell
Russell
Car: 86 iroc
Engine: 355 400hp
no i dont need one, already have which i got off an 85 transam, thanks anyway. i just didnt want to change it if i didnt have to
Car: 86\92 Mutant
Engine: 355CI 430HP
Transmission: T-5 with mods
Axle/Gears: 7.625", Eaton Posi, 3.73
A better option, IMHO, would be to ditch the Factory Proportioning valve completely and plumb in an Aftermarket adjustable unit such as a WilWood. Easy enough to do with a tubing flare kit.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
