3rd gen / 4th gen parts
Old Dec 8, 2003 | 04:20 AM
SharpSnake's Avatar
hello will a 95 firebird rearend for on a 90 firebird what about the front suspension like the a-arms and stuff
Old Dec 8, 2003 | 04:51 AM
ede's Avatar
ede
rear is a direct swap and i'd guess a lot of the front end parts will swap as well
Old Dec 8, 2003 | 07:08 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
The rear end will bolt up, but you will have to do some handy work to get the e-brake to work.
I am not familer with 4th gen front parts swapping over.
Old Dec 8, 2003 | 07:28 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The rear is a direct bolt-in, except that it's almost 2" wider on each side.
Nothing in the front is a direct swapover. They're 2 completely different designs. However some of the brake parts can be made to fit with some machine work and fabrication.
Old Dec 8, 2003 | 05:34 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Correct. 4th gens are a coil over set-up and 3rd gens use struts.
jbd1969
Aug 17, 2015 07:06 PM
redmaroz
Aug 16, 2015 11:40 PM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
sreZ28
Aug 14, 2015 07:48 PM
1nastygta
Aug 8, 2015 07:38 PM
