different wheel widths
Old Dec 8, 2003 | 10:28 AM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
Allright my car is a street car but is going to be set up to also run auto-x and possibly some road race courses. I know the basic rule for raceing is basically put the absolute most amount of rubber on the ground as possible. My question here is because i cant the rims i will hopefully be getting come in 17X8 and 17X10 and i was wondering what effect it would have on my handeling if i went with 10 inch wide out back and 8 inch up front? Am i better off with 8 inch all around? Give me some advice guys and please dont say do this and this because i say its better, if you have facts to support what youre saying it would be much appreciated.
Old Dec 8, 2003 | 11:26 AM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
you should always run as much rubber as possible and adjust any ill handling effects with suspension changes. Only rule of thumb I know of is to run the same model tire on all 4 corners. It's no big deal running a smaller front tire on a rear wheel drive car and is usually the way all rear-wheel drive cars go for racing on a course.
Who are you running autox with next year and what tires do you have in mind?
Old Dec 8, 2003 | 03:01 PM
Kandied91z's Avatar
i have to agree....
i had 9.5 front and 10.5 rear and the car handled very well on a flat surface but for common street driving it was sort of a hassle and the width up front kept me from lowering the car as much as i wanted.
i now have 8 in the front and 10 in the rear and it works great.
the tires were 275-295 for the larger rims and the new sizes are 245-285 with a 295 for the strip.
okfoz
Sep 17, 2015 10:30 AM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
Brian Anderson
Wheels and Tires
Sep 12, 2015 06:12 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
