New a arm bushings
Old Dec 11, 2003 | 06:51 PM
MFaulkner's Avatar
Car: 90 Formula
Engine: 305 TBI
New a arm bushings
My PST bushings came in the mail yesterday, but I have a few installation questions before I get to work.
1.Do the bushings come greased (between shell and inner sleeve)?
2. If they don't, any tips on getting them apart?
3.Is there a good way to get the old bushing shells out of the control arm?
Thanks in advance for the help. Those bushings are the last thing holding me back from reassembling the front end.
Old Dec 11, 2003 | 07:41 PM
craig's Avatar
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
i drilled the rubber out on the old bushing and chiseled out the metal.i think i just lightly greased themetal of the new bushings before install.
Old Dec 12, 2003 | 12:57 AM
joshwilson3's Avatar
Old Dec 12, 2003 | 03:19 AM
Frains90RS's Avatar
Car: 1990 Camaro RS
Engine: LO3: 305 TBI
Axle/Gears: 1997 Trans Am rear w/ posi -3.23
Ive read that the PST LCA bushings are nothing more than Energy Suspension's stuff. If theyre the black one's then josh is right, those would be polygraphite impregnated bushings. Theyre supposed to "self-lube," but there has been a variety of results with them and whether or not they squeak. Lubing them generously before installation would probably minimize any possibility of squeaks. I would suggest taking them somewhere to get pressed in/out. I went to NAPA as Ive heard in can be a PITA on ur own. I got charged $60 for all four(fair?). Being the genius that I am, I didnt prelube them before taking them in to get pressed , so Ive got my fingers crossed, hoping for no squeaks. My mistake, ur gain...heres a thread on how to take them apart and lube them https://www.thirdgen.org/techbb2/sho...ca+and+bushing Good luck, Efrain.
Old Dec 12, 2003 | 10:48 PM
MFaulkner's Avatar
Car: 90 Formula
Engine: 305 TBI
Thanks for the help! When I get some time (Sunday?) I'll wrestle with them, and tell you how it goes.
Old Dec 14, 2003 | 05:55 PM
MFaulkner's Avatar
Car: 90 Formula
Engine: 305 TBI
just finished up the bushings. I used a punch to tap the inner sleeves out (came out easily). Pushed the bushings out of the shells using the ball joint press and some home brew fittings (a short section of pipe and a socket. It all went remarkably smoothly. I greased them up and pressed them back in. Once the a arm was installed, they squeaked a bit, but it seems that rotating the arm up and down for a while makes them stop. We'll see if they stay quiet... On to installing springs!
One last thing. Chiltons says to torque the a arm bolts while the a arm is in normal ride position. Easy enough, and sort of makes sense, but why does it actually matter?
Ed1LE
Sep 30, 2018 09:14 AM
no green
Jan 9, 2016 09:22 PM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
