cheap rear brakes?
Old Dec 11, 2003 | 07:04 PM
Trans_AM_88's Avatar
Car: 1986/88 Frankenstein Trans Am
Engine: carbed L98
cheap rear brakes?
my passenger side rear calliper on my '88 GTA rear is all locked up...it BARELY works anymore and i think the other side is going too.
1. ive heard of a recall rebuild kit? i havent been able to find any info on it though.
2. i can get all new callipers. how much do stock replacement ones cost?
3. i can get after market callipers. mostly likely expensive.
im looking for a cheap solution to fix my problem...all i need is some rear brakes...i plan on doing brake stands (burnouts while holding the brakes) so i dont want some crazy clamping force on the rotors. any suggestions?
Old Dec 11, 2003 | 07:19 PM
1983Fbody's Avatar
Car: transam, el camino
Engine: 415
I suggest you get a line lock for when you do your burnouts
Old Dec 11, 2003 | 07:37 PM
Engine: carbed L98
i know...but just for the time being ill do a few brake stands. but as for line locks, can i use this? http://www.jegs.com/cgi-bin/ncommerc...34&prmenbr=361
Old Dec 11, 2003 | 07:38 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: cheap rear brakes?
https://www.thirdgen.org/techbb2/sea...der=descending
Old Dec 11, 2003 | 08:03 PM
Engine: carbed L98
found it https://www.thirdgen.org/techbb2/sho...threadid=58367
thanks!
Vintageracer
Jan 10, 2020 05:33 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
articwhiteZ
Aftermarket Vendor Review
Aug 18, 2015 07:26 AM
kyleb24
Aug 15, 2015 08:24 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
