rear LCA bolt size?
Old Dec 16, 2003 | 12:22 PM
jon_volk's Avatar
rear LCA bolt size?
w/o jacking the car up and measuring.....does anyone happen to know what the rear LCA bolt diameter is?
Old Dec 16, 2003 | 12:47 PM
ede's Avatar
ede
there's a sholder on one end of the bolt, are you asking the thread size? can't replace it with a hardwear store bolt. i tihnk it's a 12mm bolt
Old Dec 16, 2003 | 12:49 PM
jon_volk's Avatar
was looking for shoulder size...the diam. that is goes through the bushing.
Old Dec 16, 2003 | 01:37 PM
Kenwood's Avatar
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
GM still sells that bolt...it was a little salty when I bough mine last month but it was like $1.45 a piece.... They stocked them at the local dealership as they tend to rust up and are usually replaced whenever they do suspension work... COuld I have found a supplier for the bolt to get it cheaper??? Yeah probably...but it was not worth the waste of time over 6 dollars worth of bolts...
Old Dec 16, 2003 | 05:45 PM
MdFormula350's Avatar
http://www.spohn.net/product.cfm?productid=1408
Old Dec 17, 2003 | 01:14 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
TomP made a great post about them a while back.
Hmmm.... Here ya go:
https://www.thirdgen.org/techbb2/sho...ighlight=bolts
Ed
Old Dec 17, 2003 | 04:24 AM
ronterry's Avatar
Car: '94 Corvette
hmmm I replaced mine with 1/2-13.
12mm hmmmmmm this would explain the need to tap my 1/2's in with a mallet. But you know what, the 1/2 is probably a tighter fit and might provide less movement...
I used 1/2-13 on the whole rear end grade 8 of course.
Ron
hectre13
Dec 11, 2023 08:14 AM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
toronto formula
Nov 10, 2015 06:17 AM
knight72
Aug 10, 2015 09:32 PM
NBrehm
Aug 5, 2015 07:57 PM
