Help Quick with Front Suspension
Old Jan 9, 2004 | 01:30 PM
92F-bird_5spd's Avatar
Car: 1992 Firebird
Engine: 305 TBI
Transmission: T-5 w/ Hurst Shifter
i'm replacing most of my front driver's side suspension tomorrow or sunday and wanted as much advise as i could get on this. i'm replacing the driver's side spindle, strut, and lower control arm. obviously the spring is going to make some major problems here, but my friend has a spring compressor, so hopefully that'll help us out a little. also, when i bent all that stuff, i didn't bend any tierods or anything, but i managed to shift my front sub frame slightly to the right, the mechanic i took it to(family friend) said it moved, but it doesn't seem far enough to cause any problems. i believe he said it moved about 1/16 to 1/8 of and inch to the right. is this going to cause any major problems? i want to put sub frame connectors on in the spring, so i'm thinking i should try and move it back to straighten everything out before i do that. anyone know how i go about doing this? thanks in advance.
Old Jan 9, 2004 | 10:38 PM
ckeene502's Avatar
i think you have to drop the a arms on both side to get access to the bolts for the k member. i think its like 6 bolts
keene
naw you can get to the k member bolts with out dropping the a arms. i had to go double check.
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
cam-mike
Aug 24, 2015 07:23 AM
