Are 82 strut towers different then 86's?
Old Feb 22, 2004 | 09:59 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
Hey guys me and my brother kinda put my Edelbrock STB on today and well the main brackets that bolt to the strut towers didnt even line up to where there was enuff of the strut tower under the bracket to bolt it down. so we made some spacers out of 1/4'' mild steel. then i welded them in place. after we did that and drilled and bolted everything together and we go to install my hood pins, we shut the hood and well the brackets hit the hood. we're 100% sure its the spacers we made. my question is that is there a big diference between 1982 strut towers and 1986 strut towers? becuz my brother has the same stb on his 86 sport coupe and it bolted in no problem.
the only thing we can think of to get this to work is push the main brace down and redrill holes and then chop off the rest of the bracket. what do you guys think?
Old Feb 23, 2004 | 01:43 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
All years should be the same.
Old Feb 23, 2004 | 02:50 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The strut mounts are different, aren't they?
Old Feb 23, 2004 | 06:13 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Right.... the strut towers themselves are the same, but they changed the strut bearing mount. I'm not sure what year though.
Get a pair of those off of a newer car.... 86 up, it would appear.
Old Feb 23, 2004 | 06:35 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
My experience.
https://www.thirdgen.org/techbb2/sho...hreadid=183622
JamesC
Old Feb 23, 2004 | 07:34 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
okay well i think im goin to modify the brackets from edelbrock just for now and then make my own brackets that fit in that area but will hold the ends of the main brace. and i need to change my strut mounts someday, those i havent replaced just yet, been lookin at those billet alumin strut mounts, i wounder if theres any problem with those fitting on a 82-86 camaro/firebird.
Old Feb 24, 2004 | 08:11 PM
Spohn sells both styles. They are the same size, just the 87-up have the rear stud closer to the strut body to give a bit more caster.
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
tcflint
Sep 27, 2015 05:58 PM
