Groaning Steering '91 bird
Old Mar 6, 2004 | 01:06 AM
BigPile's Avatar
My 91 Bird is groaning really bad when I turn the steering wheel either direction. I am not sure of the steps that I should take now. I checked the power steering fluid level and it was a hair low, but not bad. I topped it off just in case. The groaning has been getting worse and worse over the last couple of months.
Any help would be greatly appreciated.
My Vehicle:
1991 Pontiac Firebird
305 V8 TBI, Automatic
157,000 miles
Thanks, Rob
Old Mar 6, 2004 | 01:15 AM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Do you have someone else do your oil change? If yes, then they may have forgotten to grease your front suspension grease fittings maybe. (Should be about 6-7 grease fittings all in the front) May want to check them out such as the ball joint fittings. I have a guy who had the same problem as you but he had a Ford Taurus. He was told that it was his steering pump but I found it to be a crack on his rack and pinion.
Old Mar 6, 2004 | 09:42 PM
BigPile's Avatar
Oh yeah! Thanks
I greased the front end today and it is all good now. The groaning is all gone now. I don't know why i didn't think of that. I have greased them in the past, but not for the last 10 months or so....forgot about them. The noise just seemed too serious to be that.
Thanks again!
Ed1LE
Sep 30, 2018 09:14 AM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
