Upgrading to larger sway bars
Old Mar 11, 2004 | 02:11 PM
blackbeauty's Avatar
Car: 1989 Trans Am
Engine: 1989 305 TPI
Transmission: 700-R4
Axle/Gears: 2.77 10 bolt
Hi everyone,
I scored for free a 36mm and 24mm sway bar that I want to put on my '82 Trans Am.
I know I will need to buy new bushes, but I'm not sure about the two clamps that hold the front sway bar in place. I don't know what you call them, but I think they're a C shape and the hold the sway bar in place in the centre (I'm not talking about the end links).
Question is, with going to larger sway bars, will I need to get different (presumably larger) C clamps? Or, will the larger bar with the new bushes fit immediately?
Also, will putting poly bushes on the sway bar affect ride quality much? I like how my car handles now, but I want to make the ride smoother.
Old Mar 11, 2004 | 02:21 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The stock "C" clamp will work. Poly bushings and end links in this area won't affect the ride much, if at all.
JamesC
Old Mar 11, 2004 | 04:01 PM
Car: 1989 Trans Am
Awesome thanks for that info, greatly appreciated.
Presumably, poly bushings will show a significant improvement in this application over rubber? If it's only a slight improvement then I'd probably go rubber since it's cheaper. I'm looking for a good return on the money spent if you get my drift.
Old Mar 11, 2004 | 05:04 PM
JamesC's Avatar
The 1LE bushings are made of a higher durometer rubber. The 36 mm is GM part # 14094389, the 24 mm 10037104. The poly end links which were stock are part # 10221779 for front and rear.
JamesC
J-money
Jan 4, 2019 09:45 AM
Antips16
Oct 30, 2015 06:42 PM
camaro1185
Oct 26, 2015 06:51 AM
87camaro87
Sep 9, 2015 10:29 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
