adjusting lakewood traction action lift bars
Old Mar 16, 2004 | 12:51 AM
camaro_91's Avatar
Car: 91 Camaro RS
Engine: just put in 305 building a 406 ci
Transmission: 700 R-4
today i installed the lakewood "tractoin actin lift bars", but i dont know how to adjust them. do i adjust them up to where the car starts to go up or do i go down where the car sits and dose it matter up or down?
thatks
Old Mar 16, 2004 | 12:57 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Didn't they come with instructions?
I believe you should set them by measuring the pinion angle and adjusting accordingly.
Old Mar 16, 2004 | 01:14 AM
camaro_91's Avatar
Car: 91 Camaro RS
the instructions are hard to follow ive read them over and over and this is what they say.
"with vehicle on level surface load controle strut links should be adjusted so that front ball rod end mount has no load on it. Adjust load controle striut to eather shorten or lengthen in order to aline mounting holes so that bot can be instaled or removed with out any bind."
any idea what they mean? Thanks
Old Mar 16, 2004 | 01:24 AM
camaro_91's Avatar
Car: 91 Camaro RS
Old Mar 16, 2004 | 01:39 AM
ksrammstein's Avatar
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
hah...I thought those things are supposed to be in laymans terms
Oh...dont be an azz, just making a stupid comment
Old Mar 16, 2004 | 02:00 AM
camaro_91's Avatar
Car: 91 Camaro RS
if you aint going to help then f-u ksrammstein
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
Lanz06
Sep 14, 2015 07:16 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
