A pop when i mash the brakes
Old Mar 25, 2004 | 04:23 PM
screamin_maro's Avatar
There is a rather loud poping noise when i mash the brakes at about 15 mph
Old Mar 25, 2004 | 04:51 PM
GTA-SPD's Avatar
Car: 94 Corvette
Engine: LT-1
Transmission: Freakin Automatic---For Now
Check your ball joints, tie rods, front springs, and all around the steering box for cracks. I'm sure that ther is something I'm leaving out, but you can do a search to find lots of info about this very problem.
Welcome to the boards.
Old Mar 26, 2004 | 10:40 PM
Marc 85Z28's Avatar
Coming from the front?
https://www.thirdgen.org/techbb2/sho...hreadid=230812
Adjust the tabs on the pads as described in the thread above. The tabs do slightly loosen over time, and create a clicking noise under low speed braking. Its caused by the pad moving in the caliper.
Old Mar 26, 2004 | 11:32 PM
bigREd car's Avatar
Car: camaro
Engine: mighty 305
Transmission: mighty 700r
what if the noise is coming from the rear???
Old Mar 27, 2004 | 05:06 AM
gen3z's Avatar
Car: '92 droptop bird
Engine: 5.7L,mild cam etc.
Transmission: modded 700r4 w/2600
try this one it has yet to fail me,put the car on a lift get an impact and tighten the front subframe bolts the noise you hear will be gone........
dbrochard
Sep 19, 2015 08:13 PM
lock1983
Brakes
Sep 9, 2015 09:08 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
