Spohn Wilwood 13" kit vs Baer 13" 2-piston kit
Old Apr 1, 2004 | 11:29 PM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
Just wondering what you guys think of these two kits and how they compare. The price is a factor and was wondering if the 4-piston caliper is worth the extra $600?
Old Apr 2, 2004 | 03:25 AM
Kandied91z's Avatar
your definately going to notice a 4 piston over 2 however most street cars won't really benefit from its true potential anyhow....however for those guys who are always on the gas it may be a good idea.
i drove a few 6 piston setups when i was looking into my 2 piece baer and never really got them up to speed on the street. the 4 piece is a nice improvement over the traditional 2 piston but is it really necessary? it's all up to the owner.
Old Apr 2, 2004 | 02:34 PM
CaysE's Avatar
What kind of speeds are the 4-pistons more efficient at?
Old Apr 2, 2004 | 02:36 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
really, its not even a constant speed.... you cant say from XXXmph, the 4 pistons are better.
you need to be on a track where you're on the brakes hard, accelerate, and on them again, over and over until they heat up... only then will you even see the diff....
Old Apr 2, 2004 | 05:55 PM
CrazyHawaiian's Avatar
Car: too many ...
I'd say you only need the Spohn 4 piston setup for serious roadrace/autox/scca track use. I'm gonna be running Spohns kit on my track car, but for my street cars I'm gonna be going with the C5 fronts on the Z28 and 1LE's on the IROC.
Old Apr 2, 2004 | 07:30 PM
Kandied91z's Avatar
yep unless your going for looks i'd just go with a stock gm component like the cheaper ls1 or c5 upgrades...
Old Apr 3, 2004 | 10:19 PM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
You can go with the Baer upgrade on the front and save yourself some bones. Or you could go with the Baer system and all of the upgrades for about the same price as what Spohn is charging. That would include polished calipers, 2 piece rotors (lighter for less unsprung weight) and cross-drilled/slotted/zinc-washed rotors.
I believe the SSBC (Stainless Steel Brakes Corporation) also sells a 1LE uprade kit that's around the price of Spohn's but doesn't require any spindle modifications. Basically, it's a 12" rotor with caliper upgrade..
Good luck in your future purchases
Colin
david068513
LSX and LTX Parts
Nov 15, 2015 11:37 PM
david068513
Sep 13, 2015 11:24 AM
david068513
South East Region
Nick McCardle
Sep 10, 2015 08:36 PM
