need big block springs- stock height
Old Apr 2, 2004 | 08:45 PM
camaro_1983_383's Avatar
hey guys, i just got another camaro with a big block but it sits just a little bit too low, maybe an inch. i have stock iroc springs on my 85 iroc-z, but as i said, i have a big block inside. nobody sells anything but lowering springs, and i cant go any lower!! i already scrape too much as it is. I can live with the height i have now, but ideally i would like to be an inch higher in the front. rear is okay but i would like new springs all the way around for better handling. Even if you can tell me stock iroc spring height and rate and i can get help picking the right spring. thanks alot
Old Apr 2, 2004 | 08:59 PM
CaysE's Avatar
My suggestion is to find out the weight up front and give Eibach or some other reputable company a call to find out your options.
Old Apr 3, 2004 | 06:16 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Moog makes stock height replacement springs in varying compression weights.
Old Apr 3, 2004 | 06:44 PM
nolanr0413's Avatar
Car: Trans am
um , check ebay they have them every once and a while, or check groundcontrol.com , they might be able to make you some springs.
Old Apr 4, 2004 | 08:10 AM
e-man's Avatar
Car: 89 formula
Engine: 383
This may help you out http://jeffd.50megs.com/Moog_Spring_Page.htm
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
camaro71633
Sep 1, 2015 10:24 AM
sailtexas186548
Aug 26, 2015 03:32 PM
sreZ28
Aug 14, 2015 07:48 PM
