Rear Traction Bar
Old Apr 16, 2004 | 08:06 AM
FastBack's Avatar
Car: 91' Firebird Formula WS6
Transmission: TH700R4
Rear Traction Bar
is a set of rear traction bars worth it? its an easy install and they are cheap but i was wondering if that actually impove traction? i just need a little more kick off the line instead of just sitting there spinning. otherwise if it isn't worth it, what are some other mods that are going to improve traction and handleing for about the same amount of money and ease of install. thanks!
Old Apr 16, 2004 | 12:11 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Traction bars are for leaf spring rears.
Old Apr 16, 2004 | 12:51 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Yep, he's right. On a 91 you will need LCA's and probably a Torque arm
Old Apr 16, 2004 | 01:05 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
if you're getting wheel hop, you'll want relocation brackets.
most of the time, wheelhop on these cars is due to the LCA angle.
relocation brackets fix the angle, allowing the weight of the car to push down on the tires instead of lifting them up.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
z28addict8490
Aug 7, 2015 08:48 PM
