Resivoir (sp) cover
Car: 1989 TTA
Engine: LC2
Transmission: Worn-out 200R4
Axle/Gears: BW 9-bolt, 3.27's
Resivoir (sp) cover
I just bought a beat-up '87 Firebird, the previous owners safety-wired the cover onto the resivior (I now I'm speling it rong, eye kant think of how too spel it write...) and the gasket is hosed up too. I just bought a replacement cover and gasket, are there any problems I should encounter in replacing the old ones? (brake fluid sloshing out of the resivoir-thingy is NOT cool...)
Car: 91 RS
Engine: 305 Tbi (L03)
I suck at spelling too but i think its reservoir. It shouldnt be too tough just be carefull cause the lid can fit kinda tight sometimes. If your really worried about it you can use a hose and your finger(kinda like the finger over the straw trick) to drain the fluid first.
Car: 1989 TTA
Engine: LC2
Fixed. Took all of five minutes, adn that was getting the new ones out of the wrapping - why couldn't the old owners do that? It wasn't that difficult...
Car: 1989 TTA
Engine: LC2
Didn't get all over the lace, but I heard that DOT 3 fluid absorbs moisture, so it would be a really good idea for me to flush out the brake system anyway. Just as long as the ghetto-cover (TM) is taken care of...
Car: 91 RS
Yep three and four both absorb water and should be changed every 2 years. No one does it thou. Im surprised more people dont switch to five. It doesnt absorb water, boils at a higher temp, and wont take the paint off your car. And the only thing you have to do to switch is a nice alcohol flush of the system.
Pac J
May 17, 2020 10:44 AM
skinny z
Oct 5, 2015 06:23 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
Dragonsys
Sep 25, 2015 03:51 PM
