Lca Relocation Brackets
Car: 1986 Iroc
Engine: 305 TPI w/30,000 original miles
Transmission: 700r4 Transgo Shift Kit
I want to pruchase brm's bolt on relocation brackets. My car is not lowered. Will the brackets affect the pinion angle or the suspension geometry? I also plan to buy 28 inch rear tires when the old ones wear out. Will that change anything? Will i still have the orginal handling in the corners? Will I get harder launches? I have jegs tubular lca's (They are very well constructed and at a very decent price compared to other companies, only con is that they do not have greaseable bushings)
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Re: Lca Relocation Brackets
just be sure to buy the brackets that WELD ON to the existing ones.. the bolt on ones can break.
i have the bolt on ones and they work great , i went drag racing with them and have put about 1000 miles on them , they are great since you dont have to screw around they are real easy to do . If you do get them you could get the bolt in ones and just weld them in if you wanted to .
