Adjustable panhard bar question
Old Apr 25, 2004 | 11:33 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Where are the best points for taking measurements when setting up an adjustable panhard bar? After swapping my old 10 bolt for a 9 bolt I haven't been able to get it exactly where it needs to be. I had no problems when working with the 10 bolt but the measurement points just aren't working with the 9 bolt. I have a Spohn on-car adjustable just fyi.
Old Apr 25, 2004 | 03:07 PM
nolanr0413's Avatar
Car: Trans am
i did mine just bye eye. If you actually wanna measure then you could set up a ruler against the gfx and then measure to the wheel . But i just did mine by eye, i also had someone else compare so it looks good.
Old Apr 25, 2004 | 03:09 PM
OLDYELLR's Avatar
Car: '85 IROC
It's probably most practical to measure the space between the tires and the inner body with weight on the suspension. It should be the same on both sides. That's where the tire will rub if it's too far off.
Old Apr 25, 2004 | 05:29 PM
Chickenman35's Avatar
Car: 86\92 Mutant
Engine: 355CI 430HP
Transmission: T-5 with mods
Axle/Gears: 7.625", Eaton Posi, 3.73
I jacked up the car under the rear diff, put some jackstands under the axle. Then I took a " Plumb Bob " and measured straight down from the outer fender lip thru the center of the whheel. Measured clearance from edge of tire to the string of the Plumb Bob. Very accurate.
I used a Metric ruler since the the divisions are smaller ( 1mm ).
First measurement showed right side at 7.5mm and left side at 11.5mm. Evened both sides up to 9.5mm.
Old Apr 25, 2004 | 05:46 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
We measured my buddies from the inside of the wheel to the frame rail. Gave a even measurement spot. Also heard of the gfx way, but just something that is a centered measurement will do.
Old Apr 25, 2004 | 06:27 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
Transmission: 700R4 w/3000 stall
Axle/Gears: 3.73 Torsen Posi, Moser Axles
I just put one of the Edelbrock adjustable units on my car and it is great, I can adjust it with the car on the ground. As for the initial set- up, I just took a 4ft level and stood it on its end against the tire sidewall and measured it and good ole fashion eyeballing it. Rearend is now centered under the car since lowering it 2 inches front and rear.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
redmaroz
Aug 16, 2015 11:40 PM
