Anything else needed for rear disc conversion?
Subscribe
Apr 28, 2004 | 10:11 PM
As it says. I know i need a proportioning valve, but other than that, is there anything else i need?
Reply 0
Apr 28, 2004 | 10:51 PM
You changing whole rears or just the brakes?
Ed
Reply 0
Apr 30, 2004 | 10:25 AM
I'll be doing this in a few days (changing the whole rear, posi drum 10 bolt for posi disc 9 bolt--temporarily), and am curious to see if I've got everything. I should because I've got the parts car sitting in my driveway....
Reply 0
Apr 30, 2004 | 09:47 PM
I'd invest in new axle hard lines unless you just have to cut and flare your own. You'll also need a set of the correct e-brake cables.
Ed
Reply 0
Apr 30, 2004 | 10:58 PM
I bought a whole new 89 1LE Camaro 9 Bolt with disc brakes, i already have the brake lines and e brake cables
Reply 0
May 1, 2004 | 12:00 AM
I used flared lines and was suppose to use bubble on the rear no leaking but could that cause a problem. I will change over once i get around to switching to the pbr's.
Reply 0
Subscribe
