Getting rims and tires, need help!
Old May 3, 2004 | 06:44 PM
Maximus's Avatar
Car: 1992 Camaro Z28
Transmission: 5spd.
Hey guys, I have a 92 Z28 and plan on getting 17x9.5 rear, and 17x8 in the front. I'm going w/ the American Racing Torque Thrust II's. I need to know all the info I would need for purchasing the rims such as backspacing, and anyhting else. I'll run the usuall 275-40-17 in the rear what would i wany to use in the front so they look like the same size? Low firewall, wide tire, no rub! Please help guys, Ive done some research and It's a big headache, "skulte adator faq"? Hoping you can help, check me out @ http://members.cardomain.com/maximusZ
Old May 4, 2004 | 03:08 AM
Kandied91z's Avatar
245/45/17 for the front if you want to match spec.
just use a tire calculator to find tire size....here is one to help you get started.
http://www.miata.net/garage/tirecalc.html
as far as the backspacing everyone is different but i'd ask crazy hawaiian what his boyds are set. i think he's running the same size as your asking which would give you a good visual as well.
Old May 4, 2004 | 09:21 AM
birdlvr's Avatar
Car: 85 Firebird
Transmission: th350
Back spacing for the 17x9.5 should be 5.25 to 5.5"
for the 17x8 should be around 4 or 4.5"
Daryl
www.selecttire.com
Old May 4, 2004 | 12:42 PM
Maximus's Avatar
Transmission: 5spd.
Thank you guys, you've been more than helpfull! I'll post some pic's when all said and done!!!:hail:
Old May 4, 2004 | 12:44 PM
Kandied91z's Avatar
do your homework and measure it out yourself otherwise you'll wind up with something you may not be happy with.
i'm running 8 with 4.5 up front
Hotrodboba400
Dec 10, 2019 07:07 PM
brockerboy
Wheels and Tires
Sep 17, 2015 03:59 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
fasteddi
Sep 10, 2015 09:32 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
