Turn on the car, the steering wheel moves
Old May 13, 2004 | 07:44 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
I replaced the whole front end except the A arms and steering knuckles last weekend. Then I had an alignment done. Now when I turn the car on (and I assume when the power steering gets pressure) the wheel jumps about 1/2 inch. Is that normal or a sign of impending doom?
Old May 14, 2004 | 08:51 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
That should be normal, when you turn the key it unlocks the steering wheel.
Old May 14, 2004 | 09:34 PM
racindaelky78's Avatar
Car: 1978 El Camino
Engine: 3??
Transmission: th350junk
completely normal,no power sterring does it too if the wheel is locked.
Old May 15, 2004 | 12:57 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Never did it before, and the wheel wasn't locked. This is after you turn the key one notch to unlock the wheel.
Old May 15, 2004 | 09:48 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
If the pin in the steering lock mechanism is pushing against the lock sprocket it can still(HOLD)the steering wheel in place.Turning the key will (release)the wheel.Ive noticed that with my car many times.
Old May 15, 2004 | 11:00 PM
5ltrbtr's Avatar
Car: 91' Z28 T-TOP
If it turns the same direction every time, no matter what position the wheel is in you could have a problem. I would go back and have the alignment check again. and tell them you want to see SAI and included angle too.
Jorlain
Aug 24, 2022 05:11 PM
AkDrifted
Aug 17, 2015 07:45 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
