centerlink to pitman arm
Old May 21, 2004 | 12:24 PM
Mavrick's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: 5 speed
Ok, i'm trying to change out my front end right now, and i can not get the centerlink seperated from the pitman arm. I'm not sure if the bolt is rusted in, or if it is simply pressed in unbeleivably hard. Any ideas? Would a ball joint fork work? I've tried hitting it from the top, and it wont budge. Help
Old May 21, 2004 | 04:39 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Use the balljoint fork. It should pop it apart. That's how I did mine.
Old May 21, 2004 | 07:15 PM
Mavrick's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
tried that, but it just started bending the fork. It is jammed in there. I eneded up leaving it on there, along with the idler arm. Don't know waht to do about those two parts. Got the tie rods installed though with no problems.
Old May 21, 2004 | 07:36 PM
ZFORCE's Avatar
Car: '87 IROC
Transmission: TH700R4
Get a small torch like a propane one and give it some heat. Maybe you can get it to expand, together with the pickle fork you should be able to separate them.
tj
Old May 22, 2004 | 01:31 AM
Mavrick's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
good idea...i'll give that a try tomorrow.
Old May 22, 2004 | 07:16 PM
Pat Hall's Avatar
Another way to get the pitman arm and center link separated is to use an air hammer with a straight shank that tapers down to a point. After you loosen the nut, screw it back on just a few threads. The nut will protect the threads from damage and also help you center the punch. Then just hit it straight down with the air hammer for several seconds and it should come undone quite quickly. I've used this method several times without fail when a separator fork wasn't working at all. Good luck!
no green
Jan 9, 2016 09:22 PM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
