Help!! wobbling in steering
Old May 30, 2004 | 10:29 PM
bac67's Avatar
Car: 91 Camaro
Engine: LO3 305 TBI
Transmission: 5 Speed
ok, ill be drivin along fine, then hit a bump(like a railroad crossing) and my steering will go crazy. my wheels will wobble back and forth about 2". i have to slow down and hold the steering tight to get it to stop. Anyone know what may be causing this???????
Old May 31, 2004 | 11:42 AM
CaysE's Avatar
Yikes! Are your lugnuts tight on the wheels? I had this happen when I somehow managed to forget to tighten the lugs on one of my wheels after working on the brakes. Does the car turn OK? If you cut the wheel to lock to make a u-turn, does the car feel like it's trying to hop? Hopefully it's just loose lugnuts, but it could be something worse...
Old May 31, 2004 | 03:04 PM
FreeLoader's Avatar
Car: 1997 Camaro z28
Engine: 350 LT1 built to LT4
Transmission: a
Axle/Gears: 3.23 posi
I'm having the same problem, and I'm pretty sure it's not the lugnuts, I even went to tire kingdom and had them do a total checkout on my car(which included them removing the front tires), so unless they kept some loose too...
...what would "something worse" be?
Old May 31, 2004 | 08:03 PM
CaysE's Avatar
Just to clear things up first, are you saying the wheels wobble in and out about 2" when this happens? Or is the steering wheel turning? There's a huge difference.
If both wheels up front wobble, something is definitely broken in the steering linkages. If only one wheel wobbles, it could be anything from loose lugnuts to failed wheel bearings to a broken spindle (doubt it's that last one). If the steering moves, as in the steering wheel and wheels move as one, it's bump-steer. This is common on lowered cars without a properly corrected suspension geometry. It could also happen if your springs are old and sagging.
Old May 31, 2004 | 09:33 PM
FreeLoader's Avatar
Transmission: a
my entire car moves.
tire kingdom said my centerlink and idler arm were crushed.
I just wanna make sure that this is all the problem is...
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
