Cheap Tires
Old Jun 5, 2004 | 06:56 PM
t roy9483's Avatar
Car: 1991 Camaro Z28
Engine: 5.7L TPI
Transmission: 700-R4
Cheap Tires
does anyone know what the cheapest tires in the size of either 245/50/16 or 255/50/16 are? i've found kuhmo echstata 711's for $57 each and i was wondering if anyone knows of anything cheaper. quality is not an issue, as long as the tires dont chunk up and fall off or go flat if i run over a stick or something.
Old Jun 6, 2004 | 12:46 AM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
where did you see them for $57 each? i just bought some 245/45/17 hankooks from www.roadwaywholesaletire.com and they had them the cheapest i could find. $61.26 each for same tire in 245/50/16
Old Jun 6, 2004 | 08:08 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Cheap tires Wht don't you try rubberbands.
Old Jun 6, 2004 | 08:29 AM
t roy9483's Avatar
Engine: 5.7L TPI
i saw them on at www.tirerack.com but that did not include shipping and handling because the warehouse is pretty much right down the street from me and most places around me work through the tire rack and give the same prices as they do without the shipping and handling.
and
the reason for cheap tires is because i'm poor and my tires are bald, this is my everyday car and i cant drive in the rain to get to work. if anyone knows how to use rubberbands as a tire let me know.
Old Jun 6, 2004 | 02:54 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
kuhmos arent bad tires for driving around. my cars had 245/40/16 712s all around when i bought it. for traction, they are flat out terrible(good smoke shows ). my crappy 305 w/3.08s couldnt even hook. cant compare them to anything handling wise, cause ive never had anything different
Old Jun 6, 2004 | 03:10 PM
DJP87Z28's Avatar
and
Well I guess being Poor, you consider your life being cheap then.
Inexpensive I understand but Cheap tires No, and that was the reason for the rubberband remark.
Old Jun 6, 2004 | 08:21 PM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
Pepboys has the Futura tires (made by Cooper) in that size. They cost $50 to $70+ depending on tire. The traction is good and the quality is good. If you get the HR rated tires instead of ZR they will cost less also. You just have to watch them and make sure they install them correctly (tread in the right direction).
Old Jun 6, 2004 | 10:31 PM
92rsbowtie's Avatar
Car: 92 rs camaro
Engine: 305 lo3
Transmission: WC t-5
i have kuhmo ecsta kh11, they are 56 apiece at tirerack.com
for their price, i like them a lot, they handle great on dry roads, have excellent traction on wet roads.
Old Jun 7, 2004 | 10:41 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
I considered 711's, but then realized they are only going to last 20,000 miles are are not worth it to mount and so on. Insead I'm getting either Indy 500, or a set of Firehawk SZ50 from a neighbor.
Old Jun 8, 2004 | 02:23 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
buy them from jegs.com do not buy from tire rack, they charge you out the wrong end on shipping.
nugentcj
Camaros Wanted
Dec 22, 2015 02:58 PM
F-body-fan
Sep 17, 2015 12:16 PM
2MNYMaros
Sep 15, 2015 11:36 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
84 TA NV
Sep 6, 2015 08:02 PM
