17 X 9s and Hooker 2055s what springs?
Old Jun 10, 2004 | 10:17 AM
jrg77's Avatar
Car: '85 Camaro
Engine: LG4 305
I've heard that the problem with the headers is bottoming out. My car currently has 15s and I can barely get my jack under the car to raise it. The plan calls for 17 inch wheels. What springs do I get to put the car at a normal ride height with those wheels? I am not aggressively looking to lower the car. We have enough dips that I would rather it sit normal than special.
It would be nice to be a bit stiffer though...
Jason
Old Jun 10, 2004 | 10:37 AM
ksrammstein's Avatar
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
First off, I think it will be hard to bottom out with the 2055s. If you want some stiffer springs to go with the larger rims, I would go with Eibach's pro-kit. But I would also recomend going with a good set of shocks if you want to go that rout.
Old Jun 10, 2004 | 05:34 PM
Frains90RS's Avatar
Car: 1990 Camaro RS
Engine: LO3: 305 TBI
Axle/Gears: 1997 Trans Am rear w/ posi -3.23
Well, I don't really have a problem with the headers bottoming out and have the one inch drop Eibach Pro-Kit and 17" wheels. Speed bumps are a whole other story I think u might find out that your car is actually lowered now, due to sagging springs so it wont go much lower. For stock spring replacements, search this forum, there are plenty of brands to choose from.
Good luck,
-Efrain
Old Jun 10, 2004 | 08:03 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
A good friend of mine runs the sportline springs with his 17x9's and 2055's. He does not bottom out either.
MrPackstin
Oct 25, 2017 08:09 PM
darwinprice
17
Oct 11, 2015 11:51 PM
Reid Fleming
Oct 10, 2015 09:56 PM
meeklay812
Oct 1, 2015 03:46 PM
Dragonsys
Sep 25, 2015 03:51 PM
