Is the Spohn 1 5/16 swaybar=Hotchkis/GM 36mm ones?
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
I noticed that Spohn's front swaybars are only 33mm (1 5/16) but they are 4130 chrome moly. I read an old post by Lon from TDS saying that the strength of 41xx steel is higher than 10xx steel. Does this mean that a 4130 33mm swaybar is just as strong(er) than a GM/ Hotchkis 36mm hollow front?
I want Spohn sway bars, but I was worried that there were better ones out there(bigger ones).
Is the 33mm Spohn SB equivalent or better than the 1LE 36mm?
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
bigger isn't always better.
the spohn bars have a higher rate than the 1le. but be wary of falling into the trap that a larger bar is going to perform better.
darwinprice
17
Oct 11, 2015 11:51 PM
luvofjah
Sep 26, 2015 08:28 PM
