Suspension Parts that cut down your ET's
Old Jun 21, 2004 | 08:21 AM
supermaxxbasher's Avatar
Car: 89 camaro RS
Engine: soon to be juiced built 357
Transmission: turbo 350
Which parts are best for cutting down your ET's.I built my engine up so now I need to work on my suspension....I know i need SFC's which I would use spohn's piece..What other parts help in the 1/4 mile? I know I need a posi but which one works the best on the street as well as on strip?Thanks
Old Jun 21, 2004 | 08:26 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Tires, LCA lowering brackets, LCAs, torque arm, SFCs, springs, shocks, sway bars.... not necessarily in that order
Old Jun 21, 2004 | 09:50 AM
JPrevost's Avatar
Car: 91 Red Sled
Tires, LCA lowering brackets, SFCs, shocks, LCAs, springs, sway bars, torque arm.... in that order .
I'd also suggest new poly bushings all around if it's still a street car.
Old Jun 21, 2004 | 12:44 PM
ksrammstein's Avatar
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
Yep...what they said
Old Jun 22, 2004 | 11:22 AM
Car: 89 camaro RS
What type of tires should I use. Should I go up to a 17" tire or should I stay with a 15" ET street tire
Old Jun 22, 2004 | 01:01 PM
It doesn't really matter. Many people on here have 17in rims, as do I, but tires do get more expensive. 15in rims will be lighter and have less unsprung weight. But most tires should be available in both sizes depending on width.
If you can find the tires I have in my sig i highly recomend those. They are becoming kind of hard to find, but if you can find them, then it is well worth it.
Old Jun 22, 2004 | 04:57 PM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
The 15s will also have more sidewall than the 17s, which will help too
customblackbird
Aug 15, 2021 10:16 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
