alston vs. hotchkis
Old Jun 22, 2004 | 05:07 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
alston vs. hotchkis
As the title states are there any benefits to hotchkis or alston subframe connectors. they look to be made essentially the same way, except one is tubular and one is sqaure wall tubing. both come powdercoated for about the same price.
Old Jun 22, 2004 | 07:06 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Just decide on the Spohn SFC's and you will not have a problem.
Spohn is the better ot two you mentioned.
Old Jun 22, 2004 | 10:46 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
actually, theyre completely different. the alston connect just behind the trans crossmember and on the back subframe. the hotchkis connect on the front subframe and go along the pinch weld back to the control arm mounting. if you have the funds, i say get both. but instead of hotchkis, spohn, because they have an extra piece that connect from the pinch weld to right by the trans crossmember
Ed1LE
Sep 30, 2018 09:14 AM
luvofjah
Sep 26, 2015 08:28 PM
3.8TransAM
Sep 17, 2015 02:16 PM
luvofjah
Sep 10, 2015 10:41 AM
84 TA NV
Sep 6, 2015 08:02 PM
