All rear suspension mods, NO front mods.
I'm installing a BW 9-bolt in the near future, and figured I'd upgrade the rear suspension while I'm back there. Will this have any negative effect since I have a stock fron suspension? No spring or shock upgrades, just LCA's, Lca relos, panhard, TA, and sway.
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Nope, just may feel tighter back there than the front is.
Ed
Ed
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Your car may be unballanced at times but I would not worry. It would look kinda funny if you put lower springs in though without touching the front. Those are so easy to put in you may want to wait till you can get to the fronts as well.
I happen to love the stock stance of my Iroc, so even at the cost of some performance, the car is not getting new springs.
...being an Iroc, I already have a wonderbar!
....Thanks for the replies!:hail:
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
my one concern would be upgrading the rear sway bar, without doing the front. If you go with a larger rear bar, the car will oversteer.
