what is the best torgue arm?
Car: 1992 camaro rs
Engine: 346 ls1
Transmission: t56
Axle/Gears: strange 12 bolt 3.73's
who makes the best torgue arm for a 3rd gen? the only one i can find are JEGS and EDELBROCK.
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
the Spohn TA is very nice. Click the banner at the top of the page.
I have the Spohn T/A with a poly bushing on the TA itself (the torque arm mounting to the tranny x-member). I honestly wish the bolt was the same size as the bushing. The bushing is a few sizes larger and there's play built into it. You can wiggle the bolt around the bushing, I would say a good 1/8". It is also the source of all the clunking. Ideally, it should pivot around the bushing, and not have up and down play from the bolt. I asked Spohn about it and he said that's the way it is, it's a compression fitting. I can't really see that as being a good thing.
Perhaps the rod-ended version is better. If so, I may just get a rod-end for it.
no green
Jan 9, 2016 09:22 PM
LT1Formula
Oct 8, 2015 08:34 PM
