suspension whoa's
Old Aug 12, 2004 | 04:50 AM
doc76239's Avatar
Car: 1989 FIREBIRD FORMULA WS6
Engine: TPI 305
suspension whoa's
My 89 firebird formula launches like a crazed cobra on crack. It launches hard out of the hole, with traction, but it's all over the place. The rear end squats down and the front jumps up . It has an all stock WS6 suspension. Shocks seem good, some rubber needs replacing. I'm thinking poly bushings and such. My lower control arm is bent at the axle side, toward the back bumper, is this normal or is it supposed to be straight. Are there aftermarket replacements? Any other ideas would be great.
Old Aug 12, 2004 | 06:02 AM
Rembrandt's Avatar
woes
woes as in agonizing woes.
mucho different from whoa's, like "whoa that car is fast"
there are many replacements for the rear lower control arms, some tubular, some boxed, poly bushed, rod ended....
spohns:
http://www.spohn.net/product.cfm?productid=1293
bmr:
http://www.bmrfabrication.com/F3-suspension.htm
Old Aug 15, 2004 | 06:08 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
Re: suspension whoa's
for the best possible traction, you want as much front end lift as you can get to transfer weight to the rear wheels, but you want to counter act the tendency of the rear to squat.....
when the back of the car squats, it is actually trying to pick the wheels off the ground, not push them down......better lca's a better torque arm, and some good springs and adjustable shocks will handle that
Old Aug 17, 2004 | 11:24 PM
RaMaiRGoD69's Avatar
Car: 88 GTA
traction
usually when you are getting good traction it is time to up the horsepower he he he
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
