spohn swaybar kit for a v6
Old Aug 19, 2004 | 01:38 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
anyone bought the spohn swaybar kit and used it on a v6? i'm getting there sfc's and want to upgrade my suspension so i'm figuring koni reds but want to get some better swaybars aswell.
Old Aug 19, 2004 | 11:42 AM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
http://www.cardomain.com/memberpage/518752/2
Old Aug 19, 2004 | 12:26 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I installed GM 24mm rear, and 34mm hallow front. Does just fine
Old Aug 19, 2004 | 08:18 PM
Joez88Camaro's Avatar
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
I've read anywhere that chromoly is twice to four times as strong as regular mild steel. Plus it has a much better memory then steel as well. Not to mention heat formed so the chromoly properly holds it's shape. Spohn's front bars is roughly 2 3/4 mm smaller then the largest and best stock one, but is solid in comparison and much much stronger. Swaybars do flex and people have this idea about the chromoly spohns shattering, but personally, if I didn't already have the 36/24mm GM combo I would have gone with the spohns. Might make the suspension a bit stiffer then most would like, but seems like the best swaybar combo on the market for our cars.
But then figure cost, spohn's is still $285, and reading about the poly bushings, endlinks, heat formed chromoly is is probably well worth the cost. My cost for the 36/24 swaybars alone was $70 and they aren't too hard to find. Figure then I did the spohn polybushings and endlinks (which I looked would probably be about $90 shipped now.) Add in $3 for rustoleum and some sandpaper and for about $165 the average joe gets some nice, though just a tad stiff imo, swaybars.
If you can sacrifice the ride quality for handling and have the cash go for it.
Old Aug 20, 2004 | 09:56 AM
Axoid's Avatar
Car: 92 Camaro RS
Transmission: T5 manual
I've been autocrossing with Spohn's sway bars for over a year now and if I haven't broken them I dought anyone else will. The 34mm/25mm bars may a big improvement with the stock springs.
Old Aug 20, 2004 | 11:45 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
thanks for all the great info guys
and vsixtoy great site
Antips16
Oct 30, 2015 06:42 PM
Nick McCardle
Sep 10, 2015 08:36 PM
luvofjah
Sep 10, 2015 10:41 AM
87camaro87
Sep 9, 2015 10:29 PM
